Trifoiler-style foils on IMOCAs?
Foils for flight
Foils for stability
Hapas (Foils for leeway resistance)
Postby Robert Biegler » Mon Sep 10, 2018 7:44 pm
Is there anything to prevent IMOCAs from using Trifoiler-style foils on either side of the hull, perhaps attached to the outriggers that provide a broad base for the standing rigging? One constraint is that there should be only one degree of freedom to how the foils move, but that condition would be met. Or would such foils be inferior to the Dali foils for any reason?
Re: Trifoiler-style foils on IMOCAs?
Postby John Perry » Tue Nov 06, 2018 2:56 pm
By Trifoiler style foils do you mean fully immersed inverted Tee foils that have flaps linked (as with the Moth main foil) to a 'wand' that senses height above water surface? If that is what you mean, then I am not sure it would be allowed under the current IMOCA class rules (2018).
Rule C.7.1(e) says: Trim tabs as well as deformable surfaces are prohibited for hull appendages, except for fixed keels, which can have a trim tab
Would the flap on a trifoiler foil be a trim tab? - if so it would not be allowed. And the alternative option of making the whole Tee foil rotate to change foil angle of attack would probably fall foul of rule C.7.1(h)
Would a foil control wand be an 'appendage'? The rules allow no more than 5 hull appendages so a trifoiler stye arrangement would use up 4 of those, then you do need a rudder or two and a keel.
The rules require foils to be retractable, an extra complication with Trifoiler style foils.
But the above is based on only a quick look at the rules, I have not studied them in detail.
As for wether Trifoiler style foils would be better than the current crop of shallow Vee foils I would have thoght that they would be more complicated and more prone to damage. If you look at the Utube videos of these boats sailing in heavy weather you can imagine that is a big factor to consider. Have foil control wands ever been used under severe ocean conditions? But possibly they could be more efficient in terms of L/D since the lifting surface could be more deeply immersed. The foils on IMOCA60 and also on trimaran floats seem to be operating so close to the surface that I suspect that much of the lift for much of the time comes from the underside (HP side) of the foil, which limits efficiency.
Postby Robert Biegler » Thu Nov 08, 2018 9:26 pm
John Perry wrote:By Trifoiler style foils do you mean fully immersed inverted Tee foils that have flaps linked (as with the Moth main foil)
No. The Trifoiler uses L-foils linked to sensor surfaces well ahead of the foil. See https://www.youtube.com/watch?v=zXSgZCDVWOM
John Perry wrote:The rules require foils to be retractable, an extra complication with Trifoiler style foils.
Could be done by rotating around the same horizontal(ish) axis as used for adjusting angle of attack.
John Perry wrote:Would a foil control wand be an 'appendage'? The rules allow no more than 5 hull appendages so a trifoiler stye arrangement would use up 4 of those, then you do need a rudder or two and a keel.
The control surfaces could be rigidly connected to the foils. I would count that as one appendage. The IMOCA class association may count it differently.
John Perry wrote:As for wether Trifoiler style foils would be better than the current crop of shallow Vee foils I would have thoght that they would be more complicated and more prone to damage.
For Moth-style foils, I don't know why there would be a difference. The lever arm to the farthest point looks pretty similar to the Dali foils in use now. The trifoiler style foils would be able to give a bit by rotating aft, and so may be less vulnerable, unless the sudden pull down is a problem.
Postby John Perry » Sun Nov 18, 2018 4:38 pm
When you mentioned the Trifoiler I somehow had the idea that you were talking about the Rave Windrider trimaran which I think was the same vintage, not the Hobie product that I think was a production version of the Longshot record holder - sorry about that.
Thinking about this again, I think there is a basic problem in applying Trifoiler type foils, or wand controlled foils, or indeed any surface tracking foils to IMOCA 60s. The problem is that the IMOCA boats are currently sailed at large heel angles, so a Trifoiler type foil mounted from the side of the hull would frequently be forced deep below the surface hence the foil angle would mostly be at maximum incidence, making the incidence control system largely redundant. Only in light airs would the heel angle and rig heeling moment be small enough that the foil might operate in a surface tracking mode rather than being forced deep below the surface. Of course, the above would not apply if the hydrofoil righting moment could be large enough to control the heel of the boat, essentially maintaining a constant heel angle regardless of sailing conditions. In the case of the new AC75 class, the intention is that the hydrofoil system will operate in this way since it will be the primary means of providing righting moment, but I would question whether this could be feasible within the restrictions of the IMOCA rule, particularly the maximum beam restriction.
Postby Robert Biegler » Tue Dec 04, 2018 6:39 pm
John Perry wrote:Thinking about this again, I think there is a basic problem in applying Trifoiler type foils, or wand controlled foils, or indeed any surface tracking foils to IMOCA 60s. The problem is that the IMOCA boats are currently sailed at large heel angles, so a Trifoiler type foil mounted from the side of the hull would frequently be forced deep below the surface hence the foil angle would mostly be at maximum incidence, making the incidence control system largely redundant.
I have thought about this for a while, and i can't decide. You can adjust the slope of the function relating the angle of attack of the foil to the heel angle through both the length of the lever arm to the forward control surface, and through how far from the centreline that control surface meets the water. So it should be possible to get any desired angle of attack at maximum heel.
The thing I can't work out is whether it's worth doing. I am not convinced that a constant angle of attack, perhaps at optiumum L/D of the foil, is best, because that neglects that at low speed, hulls can carry weight with less drag, and at high speed, a slightly higher angle of attack might still pay off by lifting the hull further out of the water, and by providing more righting moment.
John Perry wrote:Only in light airs would the heel angle and rig heeling moment be small enough that the foil might operate in a surface tracking mode rather than being forced deep below the surface. Of course, the above would not apply if the hydrofoil righting moment could be large enough to control the heel of the boat, essentially maintaining a constant heel angle regardless of sailing conditions.
I suspect the boats already need to limit their angle of heel such that the outrigger that holds the shrouds doesn't hit the water, at least not often. If they can do that with foils that change their lift only be immersion, it should work better if the foil can also change angle of attack.
John Perry wrote:In the case of the new AC75 class, the intention is that the hydrofoil system will operate in this way since it will be the primary means of providing righting moment, but I would question whether this could be feasible within the restrictions of the IMOCA rule, particularly the maximum beam restriction.
The new IMOCA Charal supposedly carries up to 80% of her weight on her foil. (I don't know either the original source or the method by which that estimate was obtained. Therefore I have no idea how reliable it is.) If true, that should give plenty of scope for increasing the lever arm of the boats weight by moving lift to lee by 2 metres or so.
I am not persuaded that heel control is worse with the self-adjusting than the fixed foil. Whether self-adjusting foils would be faster is a different question. One practical problem could be that foils shallow enough to lift out the weather foil are not efficient, but if the foils are deeper, then the weather foil stays in the water. With only one degree of freedom, it could be lifted out of the water only when the boat is nearly stopped.
Return to “Hydrofoils”
Users browsing this forum: No registered users and 0 guests
